pelements avatar image
pelements asked
Venus OS 3.20 MQTT Ac Setpoint BUG
Hello ,
Since Update 3.20 I have a Problem to write AcPowerSetpoint per MQTT...
If I write a Positive Number, all works fine but if need to send a Negative Number the MQTT Broker doesn't take the Number ...All other Values work fine ..( max inverter power ,Enable Charge ,Enable discharge )
Control over Modbus TCP works fine ...
System Aufbau
3x 15000 Quattro 48/15000/200-2x100
1x Cerbo GX
ESS run on external Control , the Cerbo GX is controlled of ah industrial Raspberry PI with Node-Red.Each phase is regulated individually
firmware update
Hey!
Fixed per beta v3.30~6.
Thank you for reporting! The clear reports helped fix this so quickly.
And apologies for that bug.
We’ll release this fix in an official release, ie v3.21, next week or the week thereafter.
Meanwhile, either run v3.14 official, or a v3.30-beta.
Have a good evening, Matthijs
