I assume I have two options to connect the Temp sensor i.e. in T-sense via Quattro or BMV 712 (this is the hardware I have).
However, I do note that two temp sensors are available, the normal sensor that came with Quattro and the optional sensor for the BMV.
My questions is, does it matter which one I use for the configuration (i.e. BMV does not have an advantage over the Quattro)?
