roadpapa avatar image
roadpapa asked
DCDC Charger bluetooth not finding device
Have an isolated charger newly installed and I believe everything is correct. When I first turn it on it doesn't locate the device when trying to connect. Tried a few times, disconnected battery and reconnected but no change.
LED on and voltage normal range
Have app on my phone for 712 and not sure what else to try.
Thanks
dc-dc charger
Can you please more exact what device you have?
Can you make a picture?
roadpapa avatar image roadpapa Matthias Lange - DE ♦ commented ·
The device is a Orion 12/12-30 converter installed in an RV with two 200AH LifePO4 batteries in parallel. I can take a picture tomorrow.
If it is a normal Orion it doesn't have Bluetooth and is not designed as a charger.
Only the Orion-Tr Smart and the new Orion XS are chargers and have Bluetooth.
roadpapa answered ·
Okay didn't know there were so many. This one is an isolated dc/dc converter Orion-TR 12/12-30.
It doesn't say TR-smart. So is this still Bluetooth? Just trying to get it up and running.
Thanks
roadpapa answered ·
Just checked and it's not the Smart version.
The box says it can also be used as a charger?
So I adjust the output initially and leave it at 14.4 volts.
No there adjustments can really be made apparently.
Have a 712 in place.
Thanks
6 comments
snoobler avatar image snoobler commented ·
No. A constant 14.4V to the battery will over-charge it.
roadpapa avatar image roadpapa snoobler commented ·
Just curious what these guys do when they simply drop in a LifePO4 in place of a LFA and do not use anything, are they overcharging constantly?
Dropping the output will really never fully charge the battery correct?
Thanks
snoobler avatar image snoobler roadpapa commented ·
Most batteries have a charging system, not just a converter, OR that converter is set to 13.6-13.8V where it's generally okay to keep an AGM battery floated.
Last night, I charged my 12.8V 100Ah LFP to 104.5Ah out of the 105Ah tested capacity at 13.6V. Started at 20A and finished at 2A - took about 7.5 hours.
Though I've told you this already elsewhere... and showed you the charge curves.
Set it to the float voltage of your battery, probably 12.7V.
Better would be to contact the seller and exchange it for the charger.
roadpapa avatar image roadpapa kevgermany ♦♦ commented ·
Okay, just when I think I've got it completed they throw a curveball. Leaving on a 6 week trip within a few days and most likely not enough time to get a different one.
Was planning on wiring bridge to D+ on alternator to charge when running, probably won't matter much will it?
If I do that and drop output to float would be kinda okay for now?
How about the area where the battery charger was topping out at that was like 13.4
Will replace with a Smart version just not right away. What good is this converter and what's it normally used for?
Thanks all
13.6V per the other forum.
roadpapa answered ·
I suppose I could also wire bridge to a switch in cab of RV and control it that way for the trip. Also be able to leave charge output at 14.4
Acceptable but not perfect?
Human BMS fail regularly.
13.6V
roadpapa answered ·
Ordered a Smart version and hopefully ships quick enough. If not I'll drop output down for the trip.
Thanks
