I have 2 magnum MSH3012M inverters. I'm installing 2 400AH lithium batteries in parallel and a Victron smart shunt 500A. I've created a diagram for the install. Is this configuration correct? If connecting both battery negative cables to the battery minus side of the shunt does that parallel the batteries or should I also have both battery negative posts combined as illustrated in the diagram below? ... Thanks!
