Hi Community,
I ran a MP II 48/5000 with a 48V/280Ah (EVE LiFePo, 16S, self-built) battery using a JK BMS.
The discharge process stops at 52V, which is around 30% SoC, but I'd like to go down to 3,0...3,1V cell voltage, means a cut-off voltage of 48..49,6.
As far as I understand the discharge limit is defined by the SoC (I usually set it to 20%, which I never reach) and the Dynamic cut-off voltage, right?
Where can I change the Dynamic cut-off voltage?
Thanks in advance for your support,
Oliver
