oliverhebo avatar image
oliverhebo asked
Phoenix Inverter 12V/1200 12V connection
Hello, thats my first question and it sounds very simple but I am looking for support.
I bought the Phoenix inverter 12V/1200 and the DC power connection is a screwed press connector.
I excpecting a M8/M10 pole and so the question for 35mm² copper cabel:
How should be a proper and correct connenction?
- pure 35mm² copper cabel and clamping by screwing or
- cabel sleeve for 35mm² like below
Thank you for the support!
Phoenix Inverter
kevgermany avatar image
kevgermany answered ·
Should be fine strand pure or tinned copper cable. I think you have the connectors that when you tighten them, the cable is flattened/spread out. Don't use the cable sleeves, just insert the bared cable and tighten to the correct torque.
