edstobi avatar image
edstobi asked
RS450/200 200 Amps output
Does the 200 A depend on the number of input strings?
So can I get 200 A output from the MPPT if I have e.g. only 3 strings connected and the strings provide enough input? e.g. 3 x 320V 11A 3520W input would be about 200 A output current for battery and inverter.
MPPT Controllersmppt rsmppt calculator
aaxc avatar image
aaxc answered ·
The maximum is 4000 W per tracker for 11520 W total (at 57.6 volts).
In theory the maximum PV array size per tracker is 7200 Wp (450 V x 20 A) but that really depends on the modules.
So yes, 3 trackers can easily utillize the whole RS450/200.
bartrs avatar image
bartrs answered ·
The manual says: Max. 4000w per tracker, max total of all trackers is 11520w, 57,6v.
11520 / 57,6 = 200A.
4000 / 57,6 = 69,44A.
3x 69,44 = 208,32A
So yes, 200A with 3 trackers is possible.
