Allan Yates avatar image
Allan Yates asked
VRM API CORS Access-Control-Allow-Origin header missing
Did the VRM API change somewhat recently? A web page I created that used to work fine, is now flagging that the API is no longer returning the access-control-allow-origin header. Testing with Postman confirms that the
header is not being returned from the pre-flight OPTONS call from the browser to the VRM API.
I had posted this over on Q&A, but just noticed the VRM API guide says to post in Modifications.
Thanks,
Allan.
headd
VRMapi
Allan Yates answered ·
@mvader (Victron Energy) Might you be able to ping the Victron folk who manage the API cloud services? This has put a dent in my monitoring of our vessel http://yates.ca/brigantine/. The API works fine when accessed outside of a web browser, but web browers are preventing client side Javascript access. Thx.
karelholubicka avatar image
karelholubicka answered ·
As a workaround, when I start chrome with "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --disable-web-security --disable-gpu --disable-features=IsolateOrigins,site-per-process --disable-features=IsolateOrigins,site-per-process --user-data-dir="C://ChromeDev"
the CORS check is not performed by chrome and your (and my) site works. But it is pain in the ass.
outsourcedguru avatar image outsourcedguru commented ·
I note that on MacOS one can edit the...
~/.bash_profile
...file and add an alias like...
alias cchrome='/Applications/Google\ Chrome.app/Contents/MacOS/Google\ Chrome --user-data-dir="/tmp/chrome_dev_session" --disable-web-security'
...and then you can start a page using...
cchrome index.html
In Windows, though, you can create the equivalent of a DOS batch file or CMD file or Shortcut file (Program Item profile) in your case to run Chrome with the specific arguments.
More info
karelholubicka avatar image karelholubicka outsourcedguru commented ·
Yes, I have my command embedded into Shortcut, on Windows it is the easiest way how to handle it.
Hey both, I missed your messages in february; but have now asked someone to check.
Have a good Sunday, Matthijs
Was able to implement a workaround; should have posted the details before now....
The API calls were failing the pre-flight browser CORS test.
The OPTIONS browser pre-file was returning the headers:
Instead of:
The workaround I found was to run these API calls through a web proxy. Turned out there is a free one (and a few paid ones) that are run for this specific use case. So my API call then now starts like:
https://corsproxy.io?https://vrmapi.victronenergy.com/v2/users/
This was good for the first call, then I found I was getting the same response over and over. There was a last_updated timestamp I was using, and it was never changing. Obviously being cached in the proxy. Adding in various “no-cache” headers didn’t help. But I did find what was termed “old fashioned cache busting. That is, adding the current time as a random parameter to the end of the URL.
var d = new Date();
var url = URL_VRM_INSTALL + '&ajy=' + d.getTime();
Now the first API call was working fine every time. But the second API call was being rejected by the proxy.
https://corsproxy.io?https://vrmapi.victronenergy.com/v2/installations/' + idSite + '/gps-download?'
Given the proxy is free, I was wondering if they might be screening out downloads due to potential large payloads. I took out the word download, and got past the proxy. Obviously I can’t change the API end point, but I found that if I encoded one of the characters in the word download, then it gets past the proxy check.
https://corsproxy.io?https://vrmapi.victronenergy.com/v2/installations/' + idSite + '/gps-%64ownload?';
Great idea, however I'm still getting this error
Access to XMLHttpRequest at 'https://corsproxy.io/?https://vrmapi.victronenergy.com/v2/users/36628/installations?extended=1&ajy=1717703948925' from origin 'https://www.XXXX.cz' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I have still to use the modified Chrome.
5 comments
Allan Yates avatar image Allan Yates commented ·
Famous last words, it used to work... In fact, it was working in the past week. Something has changed again. I am wondering if Victron has locked down even more to prevent the use of the proxy; as I am getting a 403 forbidden result. Need to investigate... Thx for pointing this out.
Doing some digging, and it appears the vrmapi is protected by Cloudflare, and Cloudflare is challenging the browser's preflight OPTIONS call when the call goes via the corsproxy site. Trying to find another cors proxy to try...
All working again... I have spun up my own web proxy to fake out CORS. If you want to use it, the URL looks like https://brigvicproxy-4b82d555ddbc.herokuapp.com/https://vrmapi.victronenergy.com/v2/users The proxy is locked down to only proxy the vrmapi host.
karelholubicka avatar image karelholubicka Allan Yates commented ·
Thanks, I'll give it a shot, when I'll be back from holidays :-)
karelholubicka avatar image karelholubicka karelholubicka commented ·
Thanks, Allan, your web proxy works like a charm.
