I have a device powered by the 48V DC power. I have the current power consumption already available in NodeRed on the Cerbo. Is there a possibility to feed in this consumption as a consumer device for the DC power?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Moved to modifications space as it's a Node-red question.
Hi @plot
You could use a custom driver setup to behave like a virtual smart shunt. Then either pass the data from node red to the "virtual" smart shunt via MQTT. Or pass it directly via dbus using exec nodes.
Here's how to do it:
howto add a driver to Venus · victronenergy/venus Wiki · GitHub
Here's an example dummy script:
velib_python/dbusdummyservice.py at master · victronenergy/velib_python · GitHub
In the dummy script you'd need to change com.victronenergy.dummyservice.ttyO1
to I think it'll be something like:
com.victronenergy.dcsource.ttyO1
or
com.victronenergy.dcload.ttyO1
but here's dbus info just in case im wrong you can find the right one.
dbus · victronenergy/venus Wiki · GitHub
Webinar Part 1 - Intro to Node-Red
Webinar Part 2- Basic Palettes
Webinar Part 3 - Advanced example
Victron Node-RED for dummies guide by Fideri
Node Red Community Space (normally hidden)
Venus OS Large (Node-RED) manual
Victron Node-RED github readme
Victron Node-RED custom nodes docs
51 People are following this question.
