In a parallel Multiplus II setup, is the battery capacity divided by 2 (for a 2 Multiplus system) in a similar way that the "AC input current limit" is half of the total system?
I guess it depends on what the system does with this setting. This system has the ESS Assistant.
I guess it must effect the C rate for the Dynamic Discharge Cutoff in the ESS Assistant?
Does it effect the aggressiveness of the charger voltage control (or P term if it's a PID controller) when in Absorption (Constant Voltage) phase? This is the main question why I wonder if it's divided by 2 so each charger can supply half the oomph.
The ESS Summary shows the battery capacity for both the master and slave Multiplus. However, some settings are only shown in the master. This leads me to think that the slave needs to know the battery capacity but it is not for the Dynamic Cutoff as that doesn't appear in the slave ESS Summary.
