New Victron energy meter (VM-3P75CT) the power for L1 is constantly wrong. The math doesn't make sense. 123V and 1.1 amps is not 14.9 watts. This just started happening a few days ago. I have a Carlos Gavazzi EM530 Connected to the exact same wires and location. EM530 When I installed the new meter a few weeks ago. The values matched each other. for a few weeks. I used Cerbo device list and a Custom Widget VRM graph to compare values. Unit is running the latest Firmware (1.05) The Cerbo GX is running latest firmware 3.14. I don't believe the Cerbo firmware has anything to do with this problem since the wrong values are seen in Victron connect, remote consol and VRM.
I did try loading old firmware on the energy meter (1.03) and Cerbo firmware 3.13 and 3.12 Reverting firmware did not fix the issue.
What can
