I'm very frustrated this is the 2nd charger I've received from Amazon and neither work....
This unit always shows "Charger is Disabled due to Remote input inactive" The Jumper wire is installed and I even installed another wire and 3 triple checked.
Also, all the settings were at 24v when I first turned on the unit even thou my system is 12v.... Now I can not lower any setting below 16 volts? I was able to set battery charging to 13v but even the input voltage lockout will not go below 16v???
This is a Orion-Tr Smart 24/12-20A Isolated DC-DC charger
Thanks for the help
