ptack avatar image
ptack asked
BMV-712 worked correctly for one month, now shows batteries charging when they are discharging
I installed a Victron BMV 712, 2 Battleborn lithium ion batteries, a Zamp rooftop solar panel system & controller and a Magnum Energy MS series inverter in my RV. Initially, the BMV-712 appeared to be tracking power (charging and discharging) accurately. However, recently the batteries had a couple of deep discharges and now the BMV-712 indicates that the system is charging the batteries even on a dark night when the solar panels have no output. Nothing has changed in the wiring of the system. Has anyone had a similar situation and what was the resolution?
BMV Battery Monitor
Are you seeing a direct and obvious “reversal”? i.e. applying a know load of 100W shows a charge of 100W?
If so, despite being a very strange occurance, can you try reversing the shunt, or shunt PCB to see if it is corrected?
Paul B avatar image
Paul B answered ·
Did Guys suggestion work for you
