Hi. I have a Victron EasySolar 5000 which when needed we bulk charge via a large 4.8KW 230V Stephill generator via the 32A outlet socket. This has just stopped outputting any voltage!
I have a smaller 3.1KW generator with only 13A UK 230V outlet plug sockets and so used a 13A to 32A connector. But as the generator gets to about 2.5KW output it shuts off with an overload error. I assume this is because it doesn’t output enough amps to run the bulk charging system in the Victron unit? Or should I looking for a separate problem? The EasySolar 5000 never charges more than 1.8KW when running off the 6KVA Stephill generator, so I figured the 3.1KW on would be ok. Can the EasySolar be told to take in a lower amp charge? Any thoughts would be appreciated. Thanks.
