I am planning the wiring for a Multiplus 2 12v 240v inverter. The manual states 2 x 50mm2 cables for both the positive and negative and a 400A mega fuse. Given that the max rating of a 50mm2 cable is 345A could two cable be run as per the pic at 50mm2?Inverter Wiring.pdf
