Hello all! We are facing the issue below: we own a Inverter Victron Multiplus 24/1200/25-16 and we want to connect a (manually starting) generator Champion Dual Fuel 7500 E2 DF, but it seems that the Inverter doesn't recognize the Generator in its Input. Thus, when we start the generator it doesn't give any power to the house, only to the batteries. Do you know how we can fix this?
P.s.: do we have to do anything to VE Config regarding the Grid parameters? Is it possible the incoming from the generator power is out of Frequency or the voltage out of limits? just some thoughts.
Thank you all!
