I'm perplexed. Perhaps someone here can help.
I have a completely off-grid system. I've been running a single quattro to an autotransformer to step up the output to split phase 110/220. It works great. I'm adding a second quattro to support additional load. I've rewired the autotransformer and the quattro AC outputs to look exactly like :
I then created a new bus configuration setting it to two phase 180 degree.
When I turn on the breaker on the autotransformer, there is about 1500W that loop between the two legs.
This isn't normal, is it?
