Hi all,
I am planning to build an off-grid lab scale test setup for batteries.
I am going to buy the following Victron components:
- 3kVA MultiPlus-II inverter
- 150/60 SmartSolarMPPT charger
- CerboGX
In the first implementation of the system, that you see below, I don't want to connect a battery to the DC bus yet, and I will be using the SmartSolarMPPT with a lab power supply (of course, the power supply is set to limit its output power/current/voltage according to the SmartSolar limits).
The AC load connected to the inverter will be small and constant, and is there just to check for proper system functioning.
Is the CerboGX able to manage the system even without a battery connected to the DC bus?
