uguraladag avatar image
uguraladag asked
Can I use victron mppt charger with different brand mppt charger?
Will I have a problem if I connect 3 pcs Victron mppt 100/30 chargers with the same set values connected in parallel to the battery main busbar and another brand mppt charger 100/40 with the same set values to the battery main busbar in parallel?
And is the wattage produced by 100/40 other brand mppt included in the total generated solar power shown on the VRM control panel?
MPPT SmartSolar
kevgermany avatar image
kevgermany answered ·
Yes you can as long as it has it's own set of panels. The non Victron unit will not be reported in VRM unless there is a BMV or smart shunt (connected to the GX ) measuring the flow to and from the battery. And then it will be a part of the total, not reported separately.
uguraladag answered ·
Thank you ,very much kevgermany
