New Build With the following Components.
Lithionics 51v battery with external BMS. BMS can wired to Ve Can on cerbo
2 5000/48v quattro inverters
450/100 mppt wired ve direct to cerbo.
When charging the batteries i always seem to get this alarm but doesn't appear on VRM log. Not sure what device is sending the alarm. Battery Bulk charge setting is at 57.6v. Sometimes i get the alarm when its at 57.2v or 57.4v. Not sure why it does this. ive triple checked all settings in the inverter and mppt controller.
