I have a Multiplus, BMV 712, Victron mppt solar controllers (4), Cerbo with connection to NMEA 2000 bus, GX50
i am trying to give priotity to solar and inverter unless the battery gets below x percent SOC. At this time I want the battery charger to come on (or connect multi to ac1 in) and charge the batteries to say 95% the revert to solar priority (turn ac1 off).
has anyone done a flow similar to this? I have seen the example for charging via Node red but if I read the logic correctly it cuts off at 50% SOC and will not charge beyond that.
help is much appreciated.
