monokristallin avatar image
monokristallin asked
Node-Red: HTTP in and HTTP Response does not work on port1880
Hi
My Venus OS runs on a Raspberry Pi 2 after an update from 2.91 Normal to 3.13 Large.
I am precisely following this little video on HTTP In and HTTP Response:
https://www.youtube.com/watch?v=HzO4wsL2Eio
When I type in venus.local, I get the console, as expected.
Unfortunatly, as shown at 0:55, my Node Red does not give me anything when entering
https://venus.local:1880/test
Website is unreachable. Also using the IP-number of the raspberry does not work.
Am I doing anything wrong or has there anything been changed recently? The port number, maybe?
What can I do to get this work?
Thanks in advance.
Node-RED
monokristallin avatar image monokristallin commented ·
An Update to VenusOS 3.20~35 did not make any difference.
phoenix avatar image
phoenix answered ·
Try https://venus.local:1881
That should give you the editor. If that works try test on the end.
monokristallin answered ·
I could answer the question myself. Phoenix is right (thanks), you have to call it like this:
https://venus.local:1881/test
But when automated, ayou should disbale warnings and disable verfy.
Like
wget  https://venus.local:1881/api  --no-check-certificate
Either that, or you follow the instructions on https://www.victronenergy.com/live/venus-os:large#q8the_browser_complains_about_non_private_connection so you don't need to disable warnings.
