Hi All
I have a Quattro 48/10000/140 in an ESS system with Cerbo GX, Smartshunt, DIY 550Ah LiFEPO4 battery (2 x 16s in parallel each with BMS for protection). ESS is set to use the Smartshunt as battery monitor.
There is 6.4kW PV on the DC side via a couple of SmartSolar MPPT 250/60
There is also 4kW PV on AC1 out with an SMA SB4000TL.
The PV is all working very well and the battery cells are very well balanced.
The problem I have noticed is that now we are in the middle of winter with little or no PV generation, the nightly charge (setting to "Keep Batteries Charged" via NodeRed) from the grid is not fully charging the battery - each day the SoC gets a little lower.
At first I thought that maybe I was not giving it enough time - but digging into the data I can see that is not the problem.
What is happening is that the Quattro completes the Bulk phase of the charging (voltage hits 55.2) but when it switches to Absorption the voltage drops to around 53.6V instead of maintaining the chosen Charge/Absorption voltage of 55.2V. You can see this in the VRM Advanced graphs below. The period from 02:38 to 03:37 is the Absorption phase but clearly the charge voltage dropped.
So, the question is, what did I miss in the settings, or is this a bug? Why did the Quattro drop the charge voltage? That must be what is happening because the behaviour when the DC PV is charging looks correct.
In the graphs above, the Bulk phase is terminating when the SoC is about 90%.
Software versions:
- Quattro: 502
- Cerbo: v3.00
Quattro is set to 55.2V Absorption, 53.6V Float, 1hr Absorption time, Fixed curve. Battery monitor enabled, State of charge when Bulk finished = 95% .
Many thanks
Kind regards
John
