Hi everyone,
my EV charging station stopped working recently. It seems like the Wallbox ist rapped in Wi-Fi Mode AP (it shows the SSID and IP on the screen). However, every time I try to put it into station mode I get after saving the following message "An error occurred during applying of new settings! Please verify settings and try again." Interestingly, when I manually put it into AP mode (although it is obviously already in that mode - although showing differently when logging in) it works perfectly fine.
current version: V3.3/1.22
wifi strength: 62dbm (has worked previously on the same WiFi)
any idea what could be the issue?
BR
