pp61 avatar image
pp61 asked
Connecting Cerbo GX to 12 volt load MPPT 75/15 and measuring AC load
Bought a Cerbo GX and want to install it next to my smartsolar 75/15. Any problem when I connect the Cerbo to the MPPT load output instead of the battery direct?
I also would like to measure the 220 volt usages when connect to the net. Is it correct I cannot use the AC current sensor connected to temperature input of Cerbo?
cerbo gx
pwfarnell avatar image
pwfarnell answered ·
You would have to turn your load output on permanently, it on only a small wire, it is easy enough to wire it direct to battery with the provided fuse.
I know you can connect an ac current sensor to the temperature terminals in a Multiplus but there is no information about this being an option fpr the Cerbo GX in the manual.
