Hi
I have 2 SOK LFP 100 Ah batteries. I have a small 10 amp charger for other smaller LFP batteries but want to step up up to a Victron solution for these larger batteries. I charge them separately for now but possibly will setup in parallel.
If I go to a 24 volt setup (series) at some point, I can either disconnect to charge or buy a 24 volt charger in the future.
Other than cost/output amperage.. what is the better solution, the ip22 in 20 or 30 amp config?
Charging time is faster and at 50%, the 30 amp is still at least at 15 amp.
thanks
