pwacquiez avatar image
pwacquiez asked
From the MPPT remote control terminals: how to create an alarm directly on VRM?
Hi all,
Is it possible to add a new automatic alarm rule on VRM, something like: remote state:
  • the switch at the remote (ID : I : Remote « H L » on/off terminals) control input of the MPPT is open?
And/or:
  • the switch at the MPPT remote control input is closed?
My goal is to have a push notification on my iPhone and by email if the permanent DC isolation controller (DOLD IL5881) is triggered.
I didn't find the right setting, I have an alarm every sunset
VRMalarmmppt state
@pwacquiez@ntymail.com lf you have an Ekrano, Venus or Cerbo GX you could use a Digital lnput coupled with the relay on the Dold insulation monitor to raise a warning.
pwacquiez avatar image pwacquiez klim8skeptic ♦ commented ·
Thank for feed-back
Yes, possible but I have to: install an auxiliary relay on the CPI, install a cable, lose an input on the CERBO. Given the possible number of alarms on VRM, I was hoping that there was also “State Remote MPPT”. maybe under another name?
pwfarnell avatar image
pwfarnell answered ·
I can only suggest setting the alarm on "MPPT State" or "Charger on/off" which are listed as alarm options on my unit and seeing if either of these are what you need. There is the option "Charge State" but I expect that alarms when it changes between bulk to absorption to float etc.
pwacquiez answered ·
I tried:
- “Mppt state; Off”: does not work: triggers alarm at sunset.
and
- “solar charger on/off; off (deprecated) and off”: nothing happens if I open the remote contact.
Or Connect the CERBO digital input directly to the MPPT remote control?
