I am running my cerbo wth 3.12 and it is causing me issues with Signal K and a few other programs. VRM works well as I have a starlink connection and things respond quickly over the VRM portal. My Signal K says it's offline because I think it tests connections to google.com. If I login via SSH and run a WGET command on google.com it can take up to 3-4 mins to respond if it does at all. Some other websites using the wget command seem to respond faster, but this doesn't make sense to me as the VRM portal works fine. Seems like the network is broken on the Cerbo somehow. I have a friend who has a cerbo who tested wget commands on his system and they runs instantaneously. Any advice on how to debug further?
