Dear Community,
Why don't my two Quattro 10kVA inverters (in parallel for 60 Hz, 120/240 VAC) appear on the VRM and or the Device List under VE.Bus? Is it likely a problem with an Ethernet cable the Cerbo GX does not like? On previous installations the Quattros always appeared.....but not this time.
Thank you for your guidance.
Jim
