dmarks-1 avatar image
dmarks-1 asked
Slit phase Quattros ignore phase relationship
Hi, I have a 2 Quattros set up in a split phase system 180 degrees. In this mobile application some marinas supply the correct power on a 50 amp 250 vac 180 degrees, some will split 3 phase 208 vac to 2 separate legs providing split phase of 120 degrees or 240 degrees. is there a way to ignore the phase difference and not have to reconfigure every time it gets to a different marina with a different power source? i am using an assistant in the master for a non Victron BMS control.
split phase
Mike Dorsett avatar image
Mike Dorsett answered ·
Basically, No. The only way around this would be to use a separate charger with a 200 - 250V input working range.
dmarks-1 answered ·
Well, that makes me sad and disappointed. But I guess its ok since I can remotely change the config and bill by the hour.
