I have a 3-phase system using Multipluss-II and alongside that, I have a single independent inverter RS. The whole system works fine, but the issue is, that when I have Multiplus on, it does not show the inverter RS in the VRM dashboard, and it does not show the correct power output. But the consumption is calculated correctly.
Do you know how to get around this issue?
