I have a Lifepo4 battery connected to cerbo for monitoring only so dvcc disabled. I have a battery smart sense connected but the mppt says low temperature cut off is disabled due to bms connected.
Battery bms is set to disconnect at 5 degrees and stops charging but the mppt still says bulk and raises voltage to absorption and then float and resets the smartshunt to 100%.
How do I setup low temperature disconnect on the mppt correctly?
