I have (6) six 100Amphr Battleborn batteries. I am trying to add to my existing system with gifted parts. Currently I have (2) Two - 300 (W) panels with the following Specifications
- Peak power(PM):300w
- Maximum Power Current(IMP):17.24A
- Maximum Power Voltage(VMP):17.4V
- Short Circuit Current(ISC):18.27A
- Open Circuit Voltage(vOc):21.4V
- Working Temperature:-20°C TO+60°C
- Tolerance:±5%
2x 300w Solar Panels wired in a 2s1p configuration INTO a Victron Energy SmartSolar MPPT 100V 50 amp 12/24-Volt Solar Charge Controller (Bluetooth)
I was recently gifted Victron Energy SmartSolar MPPT 100V 30 amp 12/24-Volt Solar Charge Controller. and wanted to wire 2 more of the same panels in to that. 2 questions, Can I use two different size charge controllers together to power same battery bank? and, Can the 100v 30A handle two of those panels at severe cold temps or should I just go with one?
