Over last 1 month I am having a issue over night with my quattro syncing with Grid (believe power company has ramped up the volts). When I connecting MK3 with Quattro it shows a UMain on AC 2 in volts in red (248-253v) and every minute or so 'Out Of Phase' pops up and the ignore ac goes to 1 from zero, so wont connect for hours sometimes all night, it will connect in the morning, from 5am (when the local farmers start milking voltage drops to 240v) I am in NZ and us NZ/AU power grid settings, is there a way adjust this. Have changed Grid settings to No Standard with Mk3 and it works fine. So not a issue with Victron hardware. I know not recommend, but changing the Grid and Generator around so Grid is on 'AC 1 in' help considering AC 1 in is actively monitored by inverter, PS once it does connect at night it stays connected generally all night,
