yhello avatar image
yhello asked
EasySolar II GX to Ekrano connection
I connected an Ekrano to an Easysolar II with a VE.Bus port. I could get the graphic with all Multiplus parameters but any from MPPT side. I tried to add a VE.direct connection but I still don't have the MPPT parameters.
How can I connect and configure my Ekrano to get all EasySolar informations (Multiplus and MPPT). Is there a way to connect EasySolar to Ekrano by wifi using console like the way to display on a PC through a web navigator ?
Thanks
EasySolar All-in-Oneekrano gx
The EasySolar II GX already has a build-in GX device, you don't need an Ekrano GX.
The VE.Bus and VE.direct are not designed to be connected to another GX device.
You have to open the EasySolar to disconnect the internal GX device.
Than you can use the VE.Bus port to connect the EasySolar to the Ekrano and a VE.direct cable from the MPPT to the Ekrano.
yhello avatar image
yhello answered ·
OK, I understand that EasySolar has a GX built-in but if I want a graphic display like Ekrano there is no other possibilities to do without disconnected the EasySolar GX inside ?
