l have 2000W from solar panels and wind generator charging 700ah lithium batteries /7 x 100ah/ , near 150A in total.
what shunt I need? 500, 1000, 2000?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
The 500A shunt will be OK for your current flow of 150A if you are going to use it to monitor just the power input from solar. However, your power consumption by your loads is also important if you are using it as a battery monitor. The 500A shunt is suitable for most situations covering up to around 6kW power draw.
48 People are following this question.
