Equipment I already have:
160W 12V solar panel
275W 24V solar panel
210ah 12V gel battery
Two Victron BlueSolar MPPT 75/15 charge controllers
Planning to connect one solar panel to one controller and the other solar panel to the second controller and then both controllers to the same battery.
My question is: should I connect all my loads to one controller only or can I connect some loads to first controller and some to the second? These controllers have max 15A loads and I wonder if I can connect more than that to two of them? For example 12A load to one controller and 14A load to the second?
Will the two controllers still be able to monitor the battery state and charge it properly simultaneously?
