I recently commissioned a Quattro-II 2x120 and setup two charge current control assistants.
One sets current to 0a and turns off charger when current should be 0 when AC in 2 (shore) is active.
The second sets current to 120a and turns off charger when current should be 0 when AC in 1 (generator) is active.
Everything works fine on generator. When on shore the Quattro-II constantly switches from pass through to bulk to pass through repeatedly for 10 to 15 seconds or so. Eventually it will stay in pass through for 20 seconds or so before going back to cycling the charger on and off. When it changes to bulk it does show additional power draw from shore and current going to the battery.
It seems as though it is fighting against another setting and i cant seem to figure out why. Any help is appreciated!
