I am either getting crazy ot the mppt excell cal is wrong .
I am having 12 panels :
| LG Neon Black 340WP | LG340N1K-V5 | 340 | 34,9 | 9,75 | 41,2 | 10,35 | -0,26 | 0,03 |
With a MPPT 450/100 currently in 2 strings of 6 on tracker 1 & 2 .
I want to put both string in parallel on tracker 1 .On the website it says that it can be done . On the excel sheet you can download it says : "PV current is higher then MPPT max input current"
Which one is correct ?
Then I would like to add 10 pieces of on tracker 2
| Jinko Tiger NEO 435Wp | JKM435N | 435 | 32,78 | 13,27 | 39,36 | 13,72 | -0,25 | 0,045 |
But I believe I will run over the exit amperage and I will need to buy a MPPT 450 / 200 Or an additional MPPT450/100
Any advise on this ?
Kenny
