I'm not able to set the battery voltages on this unit, no onboard bluetooth. I've connected it to a Cebro via ve cable but I have no options in the cerbo (that I can find) to set voltages and remote console into the unit presents no battery options (that I can find). What's the solution? Do I need the ve.direct bluetooth module to set this? I'm not seeing this clearly in the manual of the device and I don't want to buy this cable if it's not going to solve this.
I typically buy the smartsolar units with bluetooth built in but I had a special case that needed a cheaper unit so I tried this... and now pretty frustrated with the device.
