wesley-corbet avatar image
wesley-corbet asked
Dual Quattro AC input current limit
I recently added a second Quattro 48/10000 in parallel with an original Quattro 48/10000. An issue arose where the minimum input current limit increased to 21 amps (10.5amps per inverter) and the backup diesel generator that is already installed is not able to comfortably supply 21 amps. Is there a simple work around that will allow the input current limit to be reduced to around 15amps so this inverter upgrade does not cost my customer a new, larger generator?
I'm curious to know why 10.5amps is the minimum per inverter?
MultiPlus Quattro Inverter ChargerGeneratorinput current
derrick thomas avatar image
derrick thomas answered ·
The only way to lower the input limit is by disabling power assist or enabling ESS.
