striker avatar image
striker asked
Smart Battery Sense shows 15.0 Degre
I have installed Smart Battery Sense as intended. It sticks to the battery (100Ah LiFePo4). I have created a VE.Network with the Smart Solar MPPT and integrated both devices into it. The voltage and temperature are displayed in both devices in the VE Energy app. However, the temperature has remained at 15.0 degrees since installation. The room temperature changes from approx. 8 to 20 degrees.
This seems strange to me. I have disconnected the device from the power supply again and reconnected it. It remains at 15.0 degrees.
Is this normal?
Best regards
Smart Battery Sense
pwfarnell avatar image
pwfarnell answered ·
It is measuring the battery temperature not the air temperature and the battery will be much slower to respond than the air temperature. Check by removing it from the battery so it is in the air and see if it them changes temperature, or blow on it to see if it warms up or hold an ice cube on it. If it does not respond then it is broken so take it up with you supplier.
Smart Battery Sense Product Page
Smart Battery Sense Manual
