I have an OrionTR Smart in operation at our camper and switch the access via D+. So when the engine is running, the B2B charger also charges our LIFEPO4 battery.
However, this does not have a temperature cut-off for charging at sub-zero temperatures. With other Victron components (solar charger or Multiplus), the charging function can only be enabled in the configuration from a minimum temperature. Not with the Orion, however.
Does anyone have any idea how I can implement this in a sensible way?
Many thanks!
