Dear all,
As this topic seems unfortunately to pop here and there from time to time, I was wondering if someone managed to get the connection to work properly between ET112 and Cerbo GX through
DRF2659C (rs485 to zigbee)
DRF2658C (zigbee to usb, connected to cerbo)
I am stuck with doing tests with DTK software as indicated here: https://community.victronenergy.com/questions/153482/energy-meter-et112-zigbee-ccgx.html?childToView=241149#answer-241149
I have set the coordinator and router preference and I cannot get any Rx/Tx to flash quickly on any side of the link. I can only get the RS485 side to have slowly flashing Rx/Tx after I press quickly 3 times on the function buttong.
I do have some xiami sensor at home probably speaking in zigbee as well, as per the documentation this can be an issue, but unfortunately I cannot do otherwise.
Any way to check what is going on with adressing ?
Thank you in advance for your help
