As the title suggests, I'm looking to charge a 12V LifePO4 battery bank with the MPPT Smart Solar and Blue Smart chargers. From my research on the subject, it appears the charging algorithms on these two devices should work OK together. Just wanted to confirm this or would it be a good idea to up the absorption voltage on one of the chargers?
For some background, I'm setting up a power solution for a construction site application (water line heater). The site will provide generator power during normal working hours, but the solution will need to run 24/7. The genset will be the primary source of power during most daylight hours (except for weekends and holidays).
Thanks for any input.
