Multiplus II 48/5000
2x Pylontech US3000
Color Control GX
This inverter has been working flawlessly for over 12 months on ESS, now ESS will not bring in the grid when the battery reaches low state of charge. The other night the battery went to 6% and stopped outputting, then the grid took over the loads.
I noticed the VE Bus voltage is reading around 6 - 7 volts higher than the battery itself and confirmed with a meter measurement that the battery is correct. Why is the inverter reporting such a large discrepancy. So when the battery stopped the inverter was still reading the DC volts as 52.3v. I am assuming the inverter thinks the battery is fully charged.
When the battery is full at 52.3 the VE bus is showing 59.3V
Updated all firmwares and reinstalled ESS
Is the inverter faulty all of a sudden or is there anything else I can do.
