I'm about to run a large load (welder) off my Quattro that has 38KW of batteries. I don't think I'll need more power than I have, but if I do, can I turn on the EG4 chargeverter to also go toward the load so less is taken from the batteries (similar to how the MPPT provides some power and batteries supply rest with large loads)?
I have to set a voltage on the chargeverter, so I'm not sure if there could be some kind of voltage mismatch with the batteries and the chargeverter both supplying power to the Quattro.
Many thanks for any tips!
