tango avatar image
tango asked
Buffering the Battery with a Generator (3-Phase System) - Skylla to charge via 48V DC System?
I have following Setup:
3 multiplus 3000 / 48v (3 Phasen System)
Cerbo gx mit Display
10 kWh Pylontec BMS
2 x MPPT for Solar Array
The Idea/question:
The System is Grid connected - as we will not have enough days with sunshine hours to fully load the Battery 100%.
But rather then using the Grid power to charge the Battery - I'd like to use a Generator.
All the solutions are with a switch on one Phase - should the power go out it would switch over. I would like to not go this route as I would start a Generator and just run it 1-2 hours for a day maybe to support charging for example (if not remote controlled - manually for sure!)
The Current plan would be a Skylla 48/50 TG to connect it to the 48V BUS system
Would this work - can I connect it to the Cerbo GX - to see the input?
As I have a 48V System I have not seen a Skylla i which might be the "better" one for this project. So lacking more information so far I though I try this forum for support.
cerbo gxPylontechGenerator3 phaseSkylla
tango avatar image tango commented ·
I think I found the answer still:
https://community.victronenergy.com/questions/15723/skylla-as-power-supply-running-from-generator-poor.html
so a YES on making it work.
Follow up now would be as I found this as well to be useful:
https://community.victronenergy.com/questions/64849/skylla-i-48v-charger.html
Would there be a 48V i Version anywhere in the future to make the system connect better?
Mike Dorsett avatar image
Mike Dorsett answered ·
yes, this would work, however, the BMS / Cerbo has no way of controlling the charge current of the Skylla. This is not a problem if charge is ended at <80% SOC.
