I have a multiples 2-5000 with pylontech batteries and separate AC coupled solar array. I want to just charge the batteries during my off peak tariff and not when solar is being generated during the day. I am on Intelligent Octopus (7.5 off peak kWh) and their Outgoing Octopus export (15p/kWh) so I want to export any excess solar power after what the house uses and not use it to charge the batteries. None of the house power comes from the dedicated multiples AC outputs so I cannot do much about the house using solar power without a big rewire of the consumer units. I still want the batteries to run the house when solar is insufficient.
I have two charging schedules set up:
1. Start time of 23:30 and duration of 6 hours, SOC limit of 100%.
2. Start time of 05:30 and duration of 18 hours, SOC limit of 5% and self consumption set to PV&Battery.
I have just added the second schedule and it isn't working, i.e. charging is still occurring from solar when the batteries are 90% SOC so I don't understand why.
I believe I am on the latest firmware.
I have had a brief look at ESS mode 2 and it looks like this may be an alternative from MQTT but I would prefer not to have to go down this route.
Any help or guidance on how to stop the batteries charging during peak hours appreciated.
Dave.
