Hello
Yesterday night I was trying to perform the FW upgrade of Multiplus to v506. During the process power and internet went down (as described) but then the web page of VRM portal showed error (vrm disconnected) and no config file was donwloaded. Multiplus is now running the new FW but in default mode. Before I started the process, I downloaded the config file but the format is .rvsc instead of .rvms so I am not able to perofrm the merge. Also realized there is no ESS installed now. Can you please help me to sort this out?
Thank you in advance
